Caliber SRT-4 This compact crossover combines high performance with the interior room of a small SUV.
pullin my hair out
Old 11-19-2011, 08:42 AM
madlump's Avatar
madlump
madlump is offline
Default pullin my hair out
I have an 07 caliber an the batt light keeps comin on !! now i have replaced batt/ alternator an it still keeps comin on!!! any one have the same problem ?
Old 11-19-2011, 11:21 AM
steak59's Avatar
steak59
steak59 is offline
Always check TSB before any repair/diagnostic is performed to avoid unneccery repair.
There is a TSB for this, there is a Software upadate to address this issue on Caliber and PT cruiser.
NUMBER: 18-033-06
SYMPTOM/CONDITION:
Some customers may experience MIL illumination, Intermittent Generator Lamp
Illumination, Momentary (1 to 2 second) Oil indicator lamp illumination/flicker at idle or
momentary delay returning to idle after clutch actuation.
The technician may find one or more of the following DTC's or Symptoms:
P0139 - O2 Sensor 1/2 Slow Response.
P0700 - Transmission Control System (MIL REQUEST). This DTC is logged in PCM
and when TCM is checked, DTC's are not present.
P063A - Generator Voltage Sense Circuit (Intermittent Generator Lamp Illumination).
Momentary (1 to 2 second) Oil Indicator Lamp Illumination or Flicker at Idle
Momentary Delay Returning to Idle when clutch is actuated (Vehicles Equipped with
2.4L Engine and Manual Transmission (Sales Code ED3 and DD7).
(PM/MK w/MT) Module, Powertrain Control (PCM)
- Reprogram (B)
PCM need to be updated, but might as well update everything while u r at the dealership.
Quick Reply: pullin my hair out
