Also new to Forum-Needed help
I need help with removing the grill from my 1068 Dodge charger and therefore added the post (below) to the appropriate location. What I have learned is that I am not the only one that doesn't know the proper procedure to remove the grill.
Need Help with removing a grill from 1968 Dodge Charger.
I am trying to replace the left front fender. The service manual I have indicated that I have to remove the bumber and grill but offers no help. I can see that this is necessary because the fender needs to slide forward to clear some welded brackets.
The bumper is off. I have the grill, frame supporting the grill, and fender all loose. The frame around the grill and the grill itself have an interference, around the headlights and mechanism that opens their doors, that is stopping me from removing them.
Without removing every screw that I can find, resulting in a bunch of parts that I won't be able to put back together, there must be some procedure that identifies only what needs to be removed.
I am hoping that someone out there can do it blind folded and can help me identify what I need to do. And, are there any written instructions that would be easy to follow.
Thank you
John"
Thank you
John"
RE: Also new to Forum-Needed help
I've never had one apart on a '68 either, but you are probably much more likely to get the tech help you need at one of these two places: www.dodgecharger.com or www.moparts.com Both are more oriented to the claasics, and there are a bunch of knowledgeable, helpful people on both.
