DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 03-31-2007, 11:11 PM
Carabus Carabus is offline
Default 05 Caravan ABS-Brake Job Question
I am doing the front brakes on my 05 Caravan tomorrow, where is the ABS bleed screw? I have been told that I have to use this or the fluid may back up into the ABS motor? Tips???
3.8L and 4 wheel disk brakes!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
2005 Grand Caravan SXT with all options! Great vehicle if the A/C would stay charged!
1994 Caddilac Fleetwood LT1
1989 Mustang GT Ragtop
1967 Lincoln Continental
No Import Stuff Here!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 04-01-2007, 03:14 PM
Hessapp Hessapp is offline
Default RE: 05 Caravan ABS-Brake Job Question
Far as I know just bleed them like normal!! I just replaced a wheel cylinder on the wifes van with no problem!!
Old 04-01-2007, 08:22 PM
Finished the job with out bleeding and all is ok! Just compessed pistion slowly!
Just a quick tip, if you have the 3.8l motor with 4 wheel disk brakes make sure you get the pads with the hooks on each end. There are 2 listings at some stores!
__________________
Old 04-01-2007, 11:29 PM
mazdab2600 mazdab2600 is offline
the easy way to prevent crap/sediment from inside the calipers from going back into the system was to open the bleeder screw on the caliper then push the piston back this is a cheap flush
then you just top up the master with fresh fluid
most people dont realize brake fluid breaks down and soaks up moisture
lowering the boiling point(brake fade)and rusting parts/lines from inside
thats why they say replace/flush every 2yrs/??????km
__________________
99 dodge caravan 3.0
91 mazda b2600 4x4
Tags
05, 2006, abs, b2600, bleed, bleeding, brake, brakes, caliber, caravan, dodge, grand, info, job, mazda, systems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
