RE: 2006 Caravan - Hit curb Is it just Misalignment ?
there are alot of differant thing that my cause what is going on . you may have damaged the tire and it has raidal pull now or loose or worn tie rod. low air presser. the caravans have no caster adjustment so there no way to make it go stright. you can use camber to try to stop the pull but that lead to tire wear. frist thing we do at work if a non adjustable car pulls is to cross the front tires and set air psi then retest drive to see if it goes the other way. there are a lot of tires out there that pull right out of the box so to say. you might fine a tire store that has a good rep. for wheel alignment frist before you go to the dealer. good luck alan
__________________
2002 spider GT vert/89turbomini/77f150/71demon
