DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 06-17-2007, 04:47 PM
ramaccc ramaccc is offline
Default 2000 Grand Caravan A/C
My a/c is blowing warm air. Brought it to a couple friends who are mechanics and they vauumed out the system ( had 1.9 lbs in system ) I then put in stop leak and then refrigerant. Teste the system again and same, blowing warm air. They placed it on a machine and said that there was a problem with pressure and said the compressor was bad. So i vacuumed system again replaced compressor (added refrigerant oil) and then added stop leak again and R12A. Again only warm air from vents inside. Although this time I had cool air come out of the vents only for a few seconds and then that was it. Very strange. Before i replace anything else I was hoping to get some advice on what next or something that may have been missed or done incorrectly.
Thanks,
Mike.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-17-2007, 05:06 PM
next2pool next2pool is offline
Default RE: 2000 Grand Caravan A/C
Mike--the first thing I would do is to make sure the compressor is engaging. The best way to check is to have some one turn on the AC while you look underhood and see and hear if the clutch engages. You can do this by yourself if you listen closely while you turn the AC on -- you should hear and feel the engine rpm's change. If it is engaging, it could bea pluggedreciever/dryer or a temp door not moving to the cold position.
Old 06-17-2007, 08:26 PM
Dodge Tech Dodge Tech is offline
Well sence u have already possably messed up more stuff then u started out with lets do the basics.
U had 1.9 in the system do u have a dual system ? if yes then u should have put in 2.88 lbs of freeon. Single zone is 2.3 i think i hardly ever get the single zones ne more. OK the stop leak was a bad call all u did there was put stuff into the system that now has the chance of clogging up what might already be cloged up. What was the pressures like low side and high side?? both equal say 100psi with the compressor running? or was one high and the other low? Last b4 we get the cause in the first place DID U PUT OIL INSIDE THE COMPRESSOR or was it loaded from where ever u got it?
__________________
Work at a Chrysler,Dodge,Jeep Dealer<Master AC/Electrical/Engine Performance
Chrysler Dodge Jeep Tech for 11 plus years and do side work in ATLANTA if u need something done just email me.
http://home.comcast.net/~kkeller608/index.html
Old 06-17-2007, 08:27 PM
oh one last thing I hope to god U put 134a and not R12 in there.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
