Discontinued parts
Discontinued parts
My '95 GC AWD is having "Groaning" problems. Specifically, rear groaning problems whenmaking a turn and either "loading or unloading" the left rear wheel. New shocks did notsolve the problem.
The short story is that I need to replace the leaf spring bushings. Sounds simple enough, but I was told that the bushings have beendiscontinued from Mopar. I was told the only solution is to replace the wholeleftleaf spring assembly as they will have the bushings already installed. And if you do the left, you have to do the right.
So now instead of spending what I would guess is $30. in parts plus labor, I'm looking at $400. in parts plus labor.
Does ANYONE know if these bushings can be purchased and if so, where? Thanks in advance!
