DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 11-22-2007, 11:05 PM
lock0002 lock0002 is offline
Default Stiff brakes
k just bought van maybe about a month ago. Brakes seem really stiff. it take a bit of pressure to brake. I havent really tried to trouble shoot this problem yet but i was just wondering if someone could give me some input to try and help me figure this problemout so i dont have to replace parts and have it not work out. thank you
andy
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 11-23-2007, 01:32 AM
ez1913's Avatar
ez1913 ez1913 is offline
Vehicle: 96 Grand Caravan Bubbletop
Default RE: Stiff brakes
NEW FLUID!!!! First and cheapest/ safest, is to pump out the old fluid. Rust, water, and other crapy stuff weakens the fluid.
Do they change feel when hot?
Do you use the parking brake? Using the P brake adjusts the rear brake pads as they wear away. If it's never used, the front brakes must take the extra load. At 20mph when you jump on the skids, does it nose drive?
Is the brake fluid brown? should be water clear.
Second; check that the calipers are floating. The caliper should float to center itself over the rotor as the pads wear. If it gets rusted in place, only the iner brake pad gets used. Might be worth the $20 for new pads front, the problem should show itself during instulation. The chilton book lays it out, simple hand tools, a 2 on the hard meter.
Good luck,
EZ1
Old 11-24-2007, 02:25 PM
Thank you for the input. i will check these things. and post what problems may arrive
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
