DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 12-31-2007, 01:21 AM
destinysdad2003 destinysdad2003 is offline
Default throttle positioning senser
hi all im sure this has been asked before but I cant find any posts for it. I have had these 3 codes before in the last 4 weeks 4 times now:[*]
P0121-Throttle Position Sensor voltage does not agree with MAP sensor [*]
P0122-Throttle Position Sensor voltage low input [*]
P0123-Throttle Position Sensor voltage high input
I have had my van tested 3 times and I was told that the inputs and outputs were fineand it has always come back as a bad TPS and it has been replaced 4 times, the most resent one that has been replaced was ordered by the dodge dealership. my van will stall and the RPM gauge will go speradic and rev hi and low and then sometimes die, or trie to die. The check engine light does come on but mostly before it fails and stalls. the last time it stalled yesturday it did it before the light came on and I did disconnect the battery for 15 mins and reconnected it, when I did that nothing else happened and it ran fine.I am wondering if this could be a computer problem or a wiring problem like if something is grounding out and it is causing the TPS to go bad?? any advise would be very helpfull as im not to mechanicly inclined and cant afford to keep putting it into the shop to fix.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
98 dodge grand caravan 3.3l v6
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 12-31-2007, 11:41 AM
Dodge Tech Dodge Tech is offline
Default RE: throttle positioning senser
U have a wire issue take it to some one that knows what they are doing as far as electrical.
__________________
Work at a Chrysler,Dodge,Jeep Dealer<Master AC/Electrical/Engine Performance
Chrysler Dodge Jeep Tech for 11 plus years and do side work in ATLANTA if u need something done just email me.
http://home.comcast.net/~kkeller608/index.html
Old 12-31-2007, 01:59 PM
that could be anything in the wiring though right??
__________________
Old 12-31-2007, 02:09 PM
short to ground on the 3 circuits for the TPS the 5volt supply the return signal and the ground.
broken wire pinched wire.
__________________
Old 12-31-2007, 02:43 PM
hmmmm ok ill have to look. if its a short in the ground ot any of those u mentioned, is it easy to repair???
__________________
Old 01-01-2008, 08:49 AM
Rick99 Rick99 is offline
It should be easy to repair once you find it. If the conductors (metal part of the wires) are in good shape, just tape them up well. If the conductors are damaged, cut, splice, solder and tape/shrink tube.
Finding it is the trick.
Old 01-03-2008, 09:36 PM
kinda weird but ive driven my van more this week then I have in the last 3 weeks, and it is running normal, im confused now lol
__________________
Tags
caravan, dodge, p0123
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
