Intake manifold gasket replacement
Old 02-21-2008, 08:51 PM
BillRon's Avatar
BillRon
BillRon is offline
Default Intake manifold gasket replacement
I have a 2005 Dodge Caravan with the 3.3 6L engine in it. Does anyone have any good instructions on replacing the manifold gasket? Or even if you have the intake manifold bolt torque specs that would be helful. Thank you for any assistance.
Bill
Old 02-21-2008, 08:55 PM
bozzoswald's Avatar
bozzoswald
bozzoswald is offline
Default RE: Intake manifold gasket replacement
easy job-make it easier by removing the wiper cowl torque specs are 250inch pounds lower 105upper
Old 02-21-2008, 08:57 PM
BillRon's Avatar
BillRon
BillRon is offline
great what do you mean by lower and upper...i just seen a set down the middle of 8 bolts
Old 02-21-2008, 09:16 PM
bozzoswald's Avatar
bozzoswald
the upper is plastic and the lower is the aluminum intake where you are leaking
Old 02-21-2008, 09:40 PM
BillRon's Avatar
BillRon
BillRon is offline
yes i see now..i have alot of it off but i am having trouble getting the power steering resivoir off. how is it connected up under it?
Old 02-21-2008, 10:09 PM
bozzoswald's Avatar
bozzoswald
there is a 10mm nut you need to take loose form the back- near the coil pack the hole is slottled just loosen it
Old 02-21-2008, 11:10 PM
BillRon's Avatar
BillRon
BillRon is offline
thank you i got to it seems my bolts were loose. I tried to retorque and did another pressure test..no luck got to replace the gasket. So I am at the point of removing the fuel rail the injectors are so flimsy. what's the safest way to remove the fuel rail without breaking them. The clamps are all off (engine ate one) and the bolts are out.
Quick Reply: Intake manifold gasket replacement
