2005 Dodge caravan power supply/radio not working
Old 11-10-2010, 10:37 PM
speak2amy's Avatar
speak2amy
speak2amy is offline
Default 2005 Dodge caravan power supply/radio not working
My radio and power outlet are not working. I cannot seem to find this fuse in the fuse box under the hood. I unplugged a power cord and the radio turned off and the power supply no longer worked. Just seems like I blew a fuse.
Can anyone tell me where I can locate this fuse to test or replace?
Thanks!
Old 11-11-2010, 08:06 AM
jumpdrive2's Avatar
jumpdrive2
jumpdrive2 is offline
Default 05 radio
Old 12-04-2010, 12:12 AM
kenzafan's Avatar
kenzafan
kenzafan is offline
When I first bought my 2005 Dodge Grand Caravan both the radio & accessory socket were dead. After a lot of searching I was informed that if I disconnected my battery & removed it from its mounting I E, lift it out of the car I would reset the computer. Much to my delight it worked. Since then I have had my remote door lock/unlock function quit several times, & each time was corrected by this same fix. The internal power lock buttons did not work either, but did after the battery trick. There seems to be a switch under the battery. When you take the battery out leave it out for severalm minutes. If you pick it up & set back down it does not work. Hope this helps....Ken
Quick Reply: 2005 Dodge caravan power supply/radio not working
