1997 Steering pump replacement
3.3/3.8 LITER POWER STEERING PUMP
REMOVE
WARNING: POWER STEERING OIL, ENGINE COMPONENTS AND THE EXHAUST SYSTEM MAY BE EXTREMELY HOT IF ENGINE HAS BEEN RUNNING. DO NOT START ENGINE WITH ANY LOOSE OR DISCONNECTED HOSES. DO NOT ALLOW HOSES TO TOUCH HOT EXHAUST MANIFOLD OR CATALYST.
Remove the (-) negative battery cable from the battery and isolate cable.
Remove cap from power steering fluid reservoir.
Using a siphon pump, remove as much power steering fluid as possible from the power steering fluid reservoir.
Raise vehicle on jack stands or centered on a frame contact type hoist. See Hoisting, in the Lubrication and Maintenance section of this service manual for the required lifting procedure.
Disconnect the oxygen sensor wiring harness from the vehicle wiring harness. Access to connection at vehicle wiring harness is through the oxygen sensor wiring harness grommet in the floor pan of the vehicle
NOTE: The exhaust system needs to be removed from the engine to allow for an area to remove the power steering pump from the vehicle.
Remove the catalytic converter from the exhaust manifold. Then remove all the exhaust system hangers/isolators from the brackets on the exhaust system.
Move the exhaust system as far rearward and to the left side of the vehicle as possible Exhaust Position For Removing Power Steering Pump
Raise the heat sleeve on the power steering hoses to expose the hose to steel tube connection. Remove the hose from the power steering fluid return line on the front suspension cradle Power Steering Return Hose At Return Line Allow the remaining power steering fluid to drain from the pump and fluid reservoir through the removed return hose.
Remove the accessory drive splash shield Accessory Drive Splash Shield
Remove the serpentine accessory drive belt from the engine Serpentine Drive Belt And Routing See Cooling, Group 7 for detailed removal procedure.
Remove the power steering fluid supply hose coming from the remote fluid reservoir, from the fitting on the power steering pump Power Steering Hoses At Power Steering Pump Drain off excess power steering fluid from hose.
Remove the power steering fluid pressure line Power Steering Hoses At Power Steering Pump from the power steering pump. Drain excess power steering fluid from tube.
Remove the power steering fluid return hose Power Steering Hoses At Power Steering Pump from the power steering pump. Drain excess power steering fluid from tube.
Remove the support bracket at the rear of the power steering pump attaching the pump to the rear of the engine Power Steering Pump Support Bracket
Remove the 3 bolts mounting the power steering pump to the alternator/power steering pump and belt tensioner mounting bracket Power Steering Pump Mounting Bolts
Remove the power steering pump from its mounting bracket.
The power steering pump is removed from the vehicle by pulling it out through the exhaust tunnel area in the floor pan of the vehicle.
INSTALL
Install power steering pump back in vehicle using the reverse order of its removal through the exhaust tunnel are of the vehicle.
Install the power steering pump on its mounting bracket. Install the 3 power steering pump mounting bolts Power Steering Pump Mounting Bolts Tighten the power steering pump mounting bolts to a torque of 54 N·m (40 ft. lbs.)
Install the support bracket attaching rear of power steering pump to engine Power Steering Pump Support Bracket Tighten the nut and bolt holding the strut assembly to bracket and the intake manifold stud to a torque of 54 N·m (40 ft. lbs)
NOTE: Before installing power steering pressure hose on power steering pump, inspect the O-ring on the power steering pressure hose for damage and replace if required.
Install the power steering fluid pressure line onto the output fitting of the power steering pump Power Steering Hoses At Power Steering Pump Tighten the pressure line to pump fitting tube nut to a torque of 31 N·m (275 in. lbs.)
Install the power steering fluid, low pressure return hose on the power steering pump low pressure fitting Power Steering Hoses At Power Steering Pump Be sure hose clamps are properly reinstalled.
Install the power steering fluid supply hose from the power steering fluid reservoir, on the power steering pump fluid fitting Power Steering Hoses At Power Steering Pump Be sure hose is clear of accessory drive belts and all hose clamps are properly reinstalled.
Install the serpentine drive belt Serpentine Drive Belt And Routing See Cooling, Group 7 for detailed installation procedure.
Install the power steering fluid return hose on the steel tube at the front suspension cradle Power Steering Return Hose At Return Line
Install a screw type hose clamp on the power steering hose to steel tube connection. Be sure hose clamps are properly reinstalled.Tighten the screw clamp to a torque of 2 N·m (18 in. lbs.)
CAUTION: The protective heat shield sleeves must cover the entire rubber hose and hose to tube connection portion of both the power steering fluid pressure and return hoses Power Steering Return Hose At Return Line This is required to keep the power steering hoses from becoming overheated.
When used, properly position the protective heat sleeves on the power steering hoses Power Steering Return Hose At Return Line Then, tie strap the heat sleeves to the power steering hoses to keep them in their proper position.
Install the exhaust pipe on the exhaust manifold. Install all exhaust system hangers/isolators on the exhaust system brackets.
Connect the oxygen sensor wiring harness to the vehicle wiring harness. Install wiring harness grommet in the floor pan of the vehicle.
Install the accessory drive splash shield Accessory Drive Splash Shield
Lower vehicle
CAUTION: Do not use automatic transmission fluid in power steering system. Only use Mopar®, Power Steering Fluid, or equivalent.
Fill the remote power steering pump fluid reservoir to correct fluid level.
Install cap on power steering fluid reservoir.
Connect the negative battery cable on the negative battery post.
Start engine and turn steering wheel several times from stop to stop to bleed air from fluid in system. Stop engine, check fluid level, and inspect system for leaks. See Checking Fluid Level.
REMOVE
INSTALL
Lower vehicle
That is the removal and install from the service manual. Been awhile since I have done one but don't remember pulling the exhaust. I think I pulled the right axle shaft and came down that way. Possible I removed the pulley in the car as well. Labor for the job is 3.6 hrs so there is $400 of the $500 they quoted. Not sure how much the pump is.
