[5th Gen : 08+]: 2008 SXT 3.8 radiator replacement
Old 07-13-2014, 01:33 AM
RedCaravan's Avatar
RedCaravan
RedCaravan is offline
Default 2008 SXT 3.8 radiator replacement
In the morning wrenches come out to remove the radiator. I have tried everything to resolve the leaks other than the radiator so its coming out. The over heating with the bad temp sensor must have damaged it. Any good posts or links to any tricks on a 5th gen. I watched a 4th Gen video and based on my knowledge of what is under the hood I expect the 5th gen to be similar but maybe slightly easier.
Old 07-17-2014, 11:15 PM
RedCaravan's Avatar
RedCaravan
A new radiator and cap fixed it up. I did remove the front bumper and grill assembly to get access to the brackets to pop off and on the condenser and the oil pipes running across the radiator. Easy job, just a bit time consuming. I can do a full write up if needed
Old 07-18-2014, 09:52 PM
free1959's Avatar
free1959
free1959 is offline
Funny side note. I bought an 08 Caravan 2 months ago and when the salesman opened the hood, I told him I wanted to see how easy it was to change the radiator out. The last 3 used cars I have owned have needed a replacement radiator. My wife's 05 Equinox was the absolute worst one to change. The dealer gets around $600 labor for it and I found out why when I changed it. There is a pretty good place to get radiators cheap on Ebay called Automotive Cooling. They are about half the parts store price and ship pretty fast.
Old 07-19-2014, 03:12 PM
RedCaravan's Avatar
RedCaravan
I would expect to change it. They used real cheap components in the cooling circuit. The Radiator was a "Behr" but must be a real cheap grade because I have not had a Behr fail on my older Mercedes sedans. I know Behr is now making parts in China. Keep an eye on the temp sensor, thermostat and water pump. I would probably change the oem radiator cap made in mexico for an oem quality one from Advanced. Additionally I have changed the water pump, themostat and temp sensor. I believe they all needed it
Quick Reply: [5th Gen : 08+]: 2008 SXT 3.8 radiator replacement
