[4th Gen : 01-07]: A Word on Synthetic Oil, Leaking valve stem seals
Old thread resurrection! Synthetic oil has a smaller molecule to that of conventional oil so it can "find" a way out (leak).
http://www.cenex.com/about/cenex-inf...gine-oil-myths
Myth #3: Synthetic engine oils can wear down seals in an engine and cause leaks.
This is an often-cited myth. In fact, if your seals and gaskets are in good condition, synthetic oil will not leak in your engine. Synthetic oil has not been shown to deteriorate engine seals or gaskets. But it might find an existing leak. The smaller molecules of synthetic oil are able to pass through very small cracks and crevices that the larger molecules of petroleum-based oil cannot. Eventually, those small cracks and crevices can lead to bigger problems — with or without synthetic oil.
