[3rd Gen : 96-00]: computers
computers
Hi every body i have 2 issues, 1st one trans goes into neutral after starting off on a cold morning this happens after putting it in gear and moving. Its in neutral in all positions until i stop, run it thru all the positions and shut it off, this only happens when it,s close to or below freezing, 2nd question is where are the bcm, pcm, and tcm modules on this van it,s a 2000 Chrysler grand voyager 3.3 4 speed auto any info would be appreciated
BCM - Back of the junction block (fuse/relay panel) left and below steering column.
PCM - Under the hood bolted to the driver's side fender wall: https://images.search.yahoo.com/imag...TNhMwRncG9zAzM
TCM - Under the hood bolted to the passenger side fender wall:https://images.search.yahoo.com/imag...A4NgRncG9zAzQ2
