[5th Gen : 08+]: 08 caravan 4.0 just quits
Is your dealership aware of this recall?
Report Receipt Date: JUN 26, 2014
NHTSA Campaign Number: 14V373000
Component(s): AIR BAGS , ELECTRICAL SYSTEM
All Products Associated with this Recall expand
Details close
10 Associated Documents expand
Manufacturer: Chrysler Group LLC
SUMMARY:
This defect can affect the safe operation of the airbag system. Until this recall is performed, customers should remove all items from their key rings, leaving only the ignition key. The key fob (if applicable), should also be removed from the key ring. Chrysler Group LLC (Chrysler) is recalling certain model year 2009-2010 Dodge Journey vehicles manufactured June 29, 2007, to June 17, 2010, and 2008-2010 Dodge Grand Caravan and Chrysler Town and Country vehicles manufactured January 26, 2007, to June 17, 2010. Road conditions or some other jarring event may cause the ignition switch to move out of the run position, turning off the engine.
CONSEQUENCE:
If the ignition key inadvertently moves into the OFF or ACCESSORY position, the engine will turn off, which will then depower various key safety systems including but not limited to air bags, power steering, and power braking. Loss of functionality of these systems may increase the risk of crash and/or increase the risk of injury in the event of a crash.
REMEDY:
Chrysler will notify owners, and dealers will replace the ignition switch and key FOBs, free of charge. Chrysler sent out an interim notification to owners on September 11, 2014. A second notice is expected to be mailed in April 2015. Owners may contact Chrysler customer service at 1-800-853-1403. Chrysler's number for this recall is R03. Note: This is an expansion of recall 11V-139.
NOTES:
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov.
Details close
SUMMARY:
CONSEQUENCE:
REMEDY:
NOTES:
Hmm. Says it word for word in the recall. Could he be stringing you along to harvest some bucks from your wallet? Nah. Never happens. Regardless. If the recall applies to your van meaning your build date falls in the range stated you need to have it done.
Sorry to hear you're experiencing this concern. You can check out our Mopar Owner Connect website (link below) to see if your vehicle is affected by any recalls. Please keep in mind all recalls are VIN specific.
https://www.moparownerconnect.com/oc...allsQuery.aspx
