[3rd Gen : 96-00]: Tensioner Pulley Center Replacement Bolt
Old 02-03-2016, 07:00 PM
Vikingtu's Avatar
Vikingtu
Vikingtu is offline
Default Tensioner Pulley Center Replacement Bolt
I am hoping that someone out there will know where I can get a replacement bolt for my tensioner pulley. When I replaced the serpentine belt, I found that the 15mm tensioner bolt had been stripped. I had to cut the bet to remove it and use one of those stripped bolt removing tools to get the bolt out. All the major parts stores sell the pulley without the bolt that holds it to the tensioner. I have a 2000 Dodge Grand Caravan SE 3.3L Thanks for any assistance.
Old 02-04-2016, 07:52 AM
jkeaton is offline
Dodge Forum Administrator
Moved to the correct section.
Might have to go to a dealer for that.
Old 02-04-2016, 10:56 AM
Vikingtu's Avatar
Vikingtu
Vikingtu is offline
Smile
Thank you for the response. You may be correct a dealer or a junk yard, if I can get lucky there. Thanks
Old 02-08-2016, 02:38 PM
offgas's Avatar
offgas
offgas is offline
Default Ask a Mopar Technician
Go to a Mopar dealer. Ask a mechanic for a used one. They change lots of these. Probably have a bucket of used weird bolts. Just a thought.,...
Old 02-08-2016, 06:24 PM
Vikingtu's Avatar
Vikingtu
Vikingtu is offline
Thanks for the post...I will check it out.
Quick Reply: [3rd Gen : 96-00]: Tensioner Pulley Center Replacement Bolt
