[4th Gen : 01-07]: Cooing fan issue. Possible PCM?
Cooing fans work fine with the ac on but if the ac is off it will sometimes turn them on in low speed but for very little time and most of the time not at all. Funny thing is the temp gauge never passes half way even when hot steam starts overflowing out of the reservoir tank.First thing i replaced was the radiator cap. If i disconnect the temp sensor the fans will come on in high speed. I replaced the temp sensor and verified good ground and 5 volts to sensor plug. I also put in a known working ipm. At this point i have to assume the problem is the PCM as i cannot see any other option. Any advice would be appreciated before i order a new pcm. Thanks, Luis
