Brake light on dash coming on.
I have a 1990 Grand Caravan (remember those?). The brake light in the dash comes on when I hold down the brake pedal (like when sitting at a traffic light) for long periods of time. This is the same light that comes on when setting the parking brake. Anyway, I can release the brake pedal and it stays on until I quicly hit the brake pedal again. It seems to have something to do with brake pressure.
Because I have blead the brakes , I'm lead to beleave that the master cylinder may be faulty as the brakes still feel a bit spongy and if you sit long enough at a stop while in gear, the van will creep forward until you let up on the pedal and press down again (to rebuild pressure in the lines).
The calipers are new (5months ago), also the wheel cylinders. I've replaced the left front brake hose about a month or two ago and that's when I blead the system last. This light problem just started yesterday.
Has anyone ran across this problem before? And if so, what was thefaulty part?
