2006 CARAVAN SEATS
2006 CARAVAN SEATS
I RECENTLY PURCHASED A 2006 CARAVAN SXT AND HAVE DISCOVERED THAT THE DRIVER'S SEAT IS VERY UNCOMFORTABLE BECAUSE THE FRONT OT THE SEAT BOTTOM IS ANGLED SO HIGH THAT IT CUTS OFF THE CIRCULATION IN MY LEGS. I RENTED A CARAVAN WITH A POWER DRIVER'S SEAT A MONTH AGO AND FOUND IT VER COMFORTABLE BECAUSE I COULD ADJUST THE ANGLE OF THE SEAT BOTTOM.
DOES ANYONE KNOW OF A SOLUTION FOR THIS?
RE: 2006 CARAVAN SEATS
You might try putting a pillow in the seat to raise yourself so the seat doesn't cut your legs. Another solution would be to install the power seat in your van. I don't know if the earlier years power seat options will bolt to your seat. That would be the easiest to do as you probably won't find a 2006 in the yard so soon. This can be a dealer installed option, so I don't think it is too complex to add it on. Call the $tealer$hip and see what they would charge for the parts and install.
