DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 06-01-2006, 11:42 AM
stix309 stix309 is offline
Default 1996 grand caravan momemtary shudder
My Caravan has developed a shutter when at cruising speed, at any speed. Seems like it losses power for an instant then picks back up. It is very random at any speed and I don't feel anything up through th steering wheel so I dont think its the tranny however it does have 215000k on it. Any suggestions would be appreciated
Thanks in advance
Martin
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-01-2006, 02:36 PM
DodgeRam318_4bbl DodgeRam318_4bbl is offline
Send a message via ICQ to DodgeRam318_4bbl Send a message via AIM to DodgeRam318_4bbl Send a message via Yahoo to DodgeRam318_4bbl
Default RE: 1996 grand caravan momemtary shudder
Is it backfiring at all? If it is, relpace the plugs and wires.
__________________
-John-
"I reject your reality and substitute my own."
1984 D150/318/Edelbrock Carb & Intake/TCI Sizzler/0-60 In 7.0 Seconds/Now For Sale/$3,000
Touch My Truck, You Meet Jesus. Personally.
[sm=patriot.gif]
Support Our Troops
Old 06-01-2006, 02:57 PM
The vehicle does not backfire at all, I have also noticed when starting it has started to turn over longer before it will start,(not sure if that would be related to the original problem or not)
Old 06-01-2006, 06:43 PM
greaseangel greaseangel is offline
My 97 does the exact same thing! I thought I was going nuts the first couple times, because it happened so fast. Nobody could ever tell me what it was. BUT....I think I fixed it. Look at your hot wire going from the battery to the fuse box, and from the fuse box to the alternator. Both of mine were corroded inside. They showed no signs of outward corrosion. I discovered it by accident when I needed to replace the hot terminal after the old one cracked. I did the rewiring 3 weeks ago, and the "hiccup" hasn't happened since. Keeping my fingers crossed.....
Old 06-01-2006, 07:58 PM
ASH ASH is offline
Hmm, I'll have to take a look at the wires on my van when I get home. I basically have similiar symptoms. It will buck around 40 - 45 mph, seems like it could be the tranny, but I'm not sure. It has gotten much worse since I started running the AC the last few days. Thanks for the tip. When you say they were corroded inside, did you just notice this at the ends, or did you peel back the insulation and look at the whole wire?
__________________
99 Ram 1500 SLT, 4X4, Quad, Long Bed, 5.9L, 3.5 Rears, 46RE w/Shift Kit, Self-ported TB, 180 T-stat, Hypertech PPIII, 14" x 3" round air cleaner, modded TPS-CKP sensors, 100K Mi
2005 Grand Caravan Special Edition, 45K Mi.
1991 Dodge Spirit, 2.5L 190K
Old 06-01-2006, 10:09 PM
I peeled back the wire some to replace the terminal. That's how I found it. HOWEVER: I may have spoken too soon as it "hiccupped" on the way home from town this afternoon. Hm....... I had the cruise control set at 60 when it happened, and it acted like I canceled the cruise. It dropped, then the speedometer went back to 60 for a second, then the speed started slowly dropping. I hit "resume" and it went back to 60. Still I wonder why it quit for so long if it wasn't a wiring problem. Of course, there are thousands more wires.....
Old 06-02-2006, 01:27 AM
floorslayer1 floorslayer1 is offline
I had a similar (almost brief stall) but hiccup describes it well too on my 1991 3.3l GC. Mine actually ended up being my Cam position sensor, which at about 220,000 miles had finallydeveloped a short in the wire. Took forever to find. Started slowly jiggling all my connecters. and wires and finally found I could make it hesitate at that wire with regularity. Car drove fine, but at subtle bumps or accelleration to pass it would hiccup. The right motor mount would actually jiggle the wire enough to do it (yes , mount was whipped). Good Luck on this one, I really hate intermittent electrical problems because of the difficulty in isolating them.
__________________
Caravan Fan....have owned 7 and praise their virtues, but woe their transnission flaws. I use a broken differential pin as a key chain if that's any sign. 2 1988 w/2.5l, 91 GC w/3.3, 94 GC AWD w/3.3, 2 1997's w/3.3 and 99 w/3.8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
