DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 06-19-2006, 06:11 AM
NEONTHIS NEONTHIS is offline
Default 98 CARAVAN WITH 3.3
can or does someone have a how to on changing the power sterring pump
this would be most greatful
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-19-2006, 01:16 PM
dodgerules86's Avatar
dodgerules86 dodgerules86 is offline
Section Moderator
Dodge Forum Moderator
Vehicle: 1996 Dakota 4x4, 3.9L, extended cab, automatic.
Default RE: 98 CARAVAN WITH 3.3
From the book:
Removal:
(1) Remove the (-) negative battery cable from the battery and isolate cable.
(2) Remove cap from power steering fluid reservoir.
(3) Using a siphon pump, remove as much power steering fluid as possible from the power steering fluid reservoir.
(4) Raise vehicle on jack stands or centered on a frame contact type hoist. See Hoisting, in the Lubrication and Maintenance section of this MDS2 for the required lifting procedure.
(5) Disconnect the oxygen sensor wiring harness from the vehicle wiring harness. Access to connection at vehicle wiring harness is through the oxygen sensor wiring harness grommet in the floor pan of the vehicle
NOTE: The exhaust system needs to be removed from the engine to allow for an area to remove the power steering pump from the vehicle.
(6) Remove the catalytic converter from the exhaust manifold. Then remove all the exhaust system hangers/isolators from the brackets on the exhaust system.
(7) Move the exhaust system as far rearward and to the left side of the vehicle as possible.
(8) Raise the heat sleeve on the power steering hoses to expose the hose to steel tube connection. Remove the hose from the power steering fluid return line on the front suspension cradle Power Steering Return Hose At Return Line Allow the remaining power steering fluid to drain from the pump and fluid reservoir through the removed return hose.
(9) Remove the accessory drive splash shield.
(10) Remove the serpentine accessory drive belt from the engine (remember how this went on!)
(11) Remove the power steering fluid supply hose coming from the remote fluid reservoir, from the fitting on the power steering pump. Drain off excess power steering fluid from hose.
(12) Remove the power steering fluid pressure line from the power steering pump. Drain excess power steering fluid from tube.
(13) Remove the power steering fluid return hose from the power steering pump. Drain excess power steering fluid from tube.
(14) Remove the support bracket at the rear of the power steering pump attaching the pump to the rear of the engine
(15) Remove the 3 bolts mounting the power steering pump to the alternator/power steering pump and belt tensioner mounting bracket
(16) Remove the power steering pump from its mounting bracket.
(17) The power steering pump is removed from the vehicle by pulling it out through the exhaust tunnel area in the floor pan of the vehicle.
Install
(1) Install power steering pump back in vehicle using the reverse order of its removal through the exhaust tunnel are of the vehicle.
(2) Install the power steering pump on its mounting bracket. Install the 3 power steering pump mounting bolts. Tighten the power steering pump mounting bolts to a torque of 54 N·m (40 ft. lbs.)
(3) Install the support bracket attaching rear of power steering pump to engine. Tighten the nut and bolt holding the strut assembly to bracket and the intake manifold stud to a torque of 54 N·m (40 ft. lbs)
NOTE: Before installing power steering pressure hose on power steering pump, inspect the O-ring on the power steering pressure hose for damage and replace if required.
(4) Install the power steering fluid pressure line onto the output fitting of the power steering pump. Tighten the pressure line to pump fitting tube nut to a torque of 31 N·m (275 in. lbs.)
(5) Install the power steering fluid, low pressure return hose on the power steering pump low pressure fitting. Be sure hose clamps are properly reinstalled.
(6) Install the power steering fluid supply hose from the power steering fluid reservoir, on the power steering pump fluid fitting. Be sure hose is clear of accessory drive belts and all hose clamps are properly reinstalled.
(7) Install the serpentine drive belt.
(8) Install the power steering fluid return hose on the steel tube at the front suspension cradle
(9) Install a screw type hose clamp on the power steering hose to steel tube connection. Be sure hose clamps are properly reinstalled.Tighten the screw clamp to a torque of 2 N·m (18 in. lbs.)
CAUTION: The protective heat shield sleeves must cover the entire rubber hose and hose to tube connection portion of both the power steering fluid pressure and return hoses. This is required to keep the power steering hoses from becoming overheated.
(10) When used, properly position the protective heat sleeves on the power steering hoses. Then, tie strap the heat sleeves to the power steering hoses to keep them in their proper position.
(11) Install the exhaust pipe on the exhaust manifold. Install all exhaust system hangers/isolators on the exhaust system brackets.
(12) Connect the oxygen sensor wiring harness to the vehicle wiring harness. Install wiring harness grommet in the floor pan of the vehicle.
(13) Install the accessory drive splash shield
(14) Lower vehicle
CAUTION: Do not use automatic transmission fluid in power steering system. Only use Mopar®, Power Steering Fluid, or equivalent.
(15) Fill the remote power steering pump fluid reservoir to correct fluid level.
(16) Install cap on power steering fluid reservoir.
(17) Connect the negative battery cable on the negative battery post.
(18) Start engine and turn steering wheel several times from stop to stop to bleed air from fluid in system. Stop engine, check fluid level, and inspect system for leaks.
From the looks of the intructions, have fun! (Lucky for me, my truck has 6 removal and 7 installation steps, and I don't have to remove/displace half the vehicle to do it! But, thats modern day vehicles for ya!)
*oh yea, my subscription to where I got this info runs out tonight, so, I won't be able to furnish more how-to's. At $20/day or $1500/year, I could only afford enough to buy for a day, to get some info for my truck.*
If you plan on owning the van for a while, or doing your own work on it, I would suggest purchasing a factory service manual. It comes in print or CD, they are currently $90/each, but are far better than the Haynes or Chiltons manuals.
__________________
If parts ain't flyin', you ain't tryin'.
If it ain't broke, fix it 'til it is!
2009 Toyota Corolla S, 1.8L, 5-speed - the daily driver.
1996 Dodge Dakota, 4x4, extended cab, 3.9L, automatic. - my baby
Old 06-20-2006, 07:17 AM
Thanks that was a great help but i think im gonna bring it to a garage
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
