Wiring Schematic for 2005 Grand Caravan
Tizzy1, thanks for the wiring schematic!!!
Any chance you have one for the steering column too. I am trying to figure out the spot where the brake and turn signal wires come together as one. Figure this must be somewhere in the front, where I can then disconnect the connection for the brake and pull a new cable from there to the back.
Wim
Wim
Hello,
I am looking for the wiring diagram for my 2005 dodge caravan 3.3 SXT for the tail lights.
I took my car to europe and now need to change the taillights to the european version, but the rear turnsignal and brake signal use the same wire, which I now need to separate due to the separate turnsignal and brake input on the european taillights.
Thanks,
Wim
Thanks,
Wim
What part of Europe? I brought mine to Germany with me and nothing needed to be changed out. The military has a SOFA (standard of forces agreement) with Germany. If you came over with the military (whether as military or civilian) you might want to check before replacing wiring, taillight assemblies, etc.
