DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 09-17-2006, 04:19 PM
cbangs cbangs is offline
Default Pass Floor Wet From Air Con Leak
Can ahyone help? I some times have water in pass floor, i have checked and it is from air con drain >dodge sold me a o-ring but i dont see how to put it on,there is a hard plastic drain tube on firewall and it will not come off?so how do i stop the leaking into the pass floor>please help
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-17-2006, 06:07 PM
rube740 rube740 is offline
Default RE: Pass Floor Wet From Air Con Leak
Wow, I have the same problem and can't get it fixed I hope someone will help you.
__________________
Caravan 4 cyl
Old 09-19-2006, 04:50 AM
zum_23 zum_23 is offline
have you looked at the heater core to see if its leaking
Old 09-19-2006, 10:30 PM
bluer101 bluer101 is offline
It just might be that the drain tube is clogged with buildup. Try to blow out the drain tube.
Old 09-21-2006, 12:42 AM
67cobain94 67cobain94 is offline
Send a message via AIM to 67cobain94 Send a message via Yahoo to 67cobain94
The Caravans have a problem with the drain tube not draining. It's not that they're clogged they just don't drain it seems like the engine is blowing the water right back in the hole. If you take your van to your Dodge dealership they will install a molded 90 degree hose on the end of the drain tube and that will correct it. There isn't a specific part number for the hose or anything, I believe it's actually an Evap canister hose off of something but we keep them in at stock at the dealership because they are perfect. The dealer will charge you an hour to do it because it's 100 times easier if you have a lift. All you need to do is go from straight under the vehicle with it ice cold and put your arm through the holes in the subframe and slip a 90 degree hose right over the drain tube. I hope this helps some.
Old 09-24-2006, 05:45 PM
poppabear poppabear is offline
I had that problem with my 90. I found the rubber drain tube and found it clogged with dirt and lint, i took a razor and cut above it to make the hole larger and never had the problen again
Old 09-26-2006, 11:10 AM
thanks, i talked to my dealer and they sold me a 90 degree drain tube from a jeep wrangler to put on the drain tube and it solved the problem.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
