RE: How to instal a remote entry
There is only one central control module, located on the firewall to the left of the steering column. 4 large connectors. You need to find 1% tolerance resistors to use to pulse the body module, not available at radio shack. You could probably use the 5% ones available if you live somewhere there isn't huge temperature swings (affects the resistance values and the BCM is very sensitive to the correct voltage). You can't pulse the switches, the switches are the ones pulsing the BCM, you have to run seperate wires into the BCMs existing connection to the door switches. Connector 3 of the BCM (Black/White Connector) there is a violet and dark green wire that is the signal from the drivers door to the BCM, the passenger door is Violet and Light Green. I usually use one wire for the lock and the other for the unlock, to keep the aftermarket module isolated better.
__________________
Dodge/Chrysler/Jeep Technician 14 Years, ASE Master Certfied
1996 Jeep Grand Cherokee Laredo 75,600 miles
1999 Dodge Dakota Sport 318ci 135000 miles
2008 Chrysler Town and Country Limited 2500 miles
