01 CARAVAN INSTRUMENT PANEL
Wierd happenings with my Gr. Caravan. I went to reset my odometer after filling the fuel tank. All the dash lights came on, speedometer and odometer went right around. Now both indicator needles are on the wrong side of the resting post. Therefore both needles do not move when I drive. What do I do?
Thanks
Thanks
RE: 01 CARAVAN INSTRUMENT PANEL
A little odd I may say. The only way for yourself to do it is to remove the instrument cluster from the vehicle, turn it upside down until the needles are pointing at the top and then rotate the cluster right side up until the needles are setting on the right side of the stops. Or just turn the whole van upside down!
