Will Not Start 3.3L 97 Caravan
I need some help on this issue. Retrived the codes and found cam sensor needed to be replaced. So I replaced the cam, and crank sensor and the coil pack and the car will not start. Checked the voltage at battery and found 12.45 volts. I checked power to the coil pack and I don 't have power. The book says it might be the ASD relay. Question, where is the ASD relay on a 97 Cravan.
Thanks in advance
Mike
Thanks in advance
Mike
