Wet pass floor agian?
RE: Wet pass floor agian?
I have the same problem, I believe, from reading forums on the internet, it is the drain hose(s) that are clogged up. You can seethe hosefrom the engine compartment, located just above the alternator pulley/belt. I disconnected mine and it's clearly frozen with ice, trapped water unable to go anywhere. The good news is that with the freezing weather, I suppose that won't be a problem until spring .
