RE: 93 Caravan Transmission Troubles
I would get the codes pulled, and then I would look into the solenoid pack as the source of trouble. I had this with my 91 GC. When the tranny was rebuilt they may not have changed the solenoid pack and the tiny mesh screens can get plugged with metal. If it was not changed the metal from normal wear n tear may have built up enough to cause this. When you turn it off , the system pressure drops and enough falls away from the screens for the normal solenoid pressures to be present at startup. The solenoid pack is right on the front of the tranny and held in place by 1 (8mm or 10mm) bolt and an electrical connector.
If the pack was indeed changed when the tranny was rebuilt, then this might be a sign of impending doom. Good Luck
__________________
Caravan Fan....have owned 7 and praise their virtues, but woe their transnission flaws. I use a broken differential pin as a key chain if that's any sign. 2 1988 w/2.5l, 91 GC w/3.3, 94 GC AWD w/3.3, 2 1997's w/3.3 and 99 w/3.8
