High beam indicator issue
Old 10-22-2014, 03:22 AM
Raynman59's Avatar
Raynman59
Raynman59 is offline
Default High beam indicator issue
I have a 2007 Charger RT. Recently, the high beam indicator will light up on the instrument panel, although the high beams themselves are not on. The only way it will turn off when this happens is if I turn on the lights and then click the high beam switch on and then off ....
Any ideas as to what's going on?
Old 10-22-2014, 10:10 AM
DodgeCACares's Avatar
DodgeCACares
DodgeCACares is offline
Raynman59,
I'm sorry to hear about your concern. This could be the result of a loose connection or wiring concern, or possibly an issue with the multifunction switch.
Does this occur every time you start the car?
Old 10-22-2014, 10:16 AM
DodgeCares's Avatar
DodgeCares
DodgeCares is offline
It could be the front control module which controls the headlamps.
Quick Reply: High beam indicator issue
