2010 Charger Door Lock Problem
Old 02-16-2017, 03:51 PM
CBD's Avatar
CBD
CBD is offline
Default 2010 Charger Door Lock Problem
I have had several problems with wiring on my Charger. When the truck release stopped working I found out that almost all the wiring to the trunk was cut - the gauge of wiring is not robust enough for constant opening and closing. That was relatively easy to fix. I suspect that the problem is the same at the driver side door as there are multiple problems (interior lighting, window control and driver door lock) . Does the door have to be removed to repair the wiring inside the flexible rubber cover ?
Old 02-16-2017, 05:56 PM
jkeaton is offline
Dodge Forum Administrator
Moved to the correct section.
Quick Reply: 2010 Charger Door Lock Problem
