Oil change reset
Old 03-15-2017, 01:19 AM
Russ528's Avatar
Russ528
Russ528 is offline
Default Oil change reset
How do i get rid of the oil change notification
My oil cgange was done 3 months ago
Old 03-15-2017, 01:20 AM
Russ528's Avatar
Russ528
Russ528 is offline
i have a 2012 Dodge Charger SE
Old 03-15-2017, 07:21 AM
jkeaton is offline
Dodge Forum Administrator
Hello and welcome to the forum. Moved to the Charger section.
Your owners manual will tell you how to reset the oil change indicator light, but here are the steps:
1. Turn the ignition key to position “ON” without starting the engine, If your Dodge Charger has push-button start, press the “Start” button twice without touching the brake pedal.
2. Fully depress accelerator pedal slowly three times within 10 seconds
3. Turn the ignition Off
Old 03-15-2017, 11:49 PM
Russ528's Avatar
Russ528
Russ528 is offline
Thank you
P.S my car came with a manual bit its not in great condition due to water damage
When i bought the car i was going through it and it was undetneath the battery
I gues the previous owner used it as a spacer to keep the battery from bouncing around
Old 03-16-2017, 07:46 AM
jkeaton is offline
Quick Reply: Oil change reset
