Power Steering fluid?
Old 03-25-2006, 02:18 AM
cj7 bob's Avatar
cj7 bob
cj7 bob is offline
Default Power Steering fluid?
When I purchased this 2003 2500 4X4 cummins the power steering fluid was low, so it now has regular power steering fluid mixed in it. Just found out you need ATF+4. Should I drain the whole system and if so what is the easiest way to drain all the fluid?
Old 03-30-2006, 03:39 PM
steved's Avatar
steved
steved is offline
Default RE: Power Steering fluid?
ORIGINAL: cj7 bob
Yes, drain it...I believe you can remove one line from the pump (the return line) and shoot it into a bucket while someone else adds fluid at an idle...I have read where normal PS fluid causes issues in the newer rams for some reason...
steved
Quick Reply: Power Steering fluid?
