ESP/BAS Light on dash! Please Help!!!!
#72
My engine light came on then my ESP/BAS lights came on after a while of driving. When I would turn off my car the ESP/BAS light would go off but engine light stayed on so I had my 2010 Dodge Journey scanned by Autozone and the error code read as Brake Light Switch so I bought the part that cost 7.99 and replaced the brake light switch located under the brake pedal and now the engine and ESP/BAS dash lights are off but the engine light code had to be cleared with the scanner. Hope this helps!
#73
Fyi
This is about my 05 Dosge Magnum RT.
Hi. I just replaced both tie rod ends and didnt have time to aligne them. So I start driving it and the same light came on. I am pretty sure that it will off after the aligment. My car is now at the shop. As soon I have an answer I will let you know.
