Common Dodge Neon Repairs and Problems
#162
I have searched and found nothing like this, so I would welcome suggestions. My 2002 Neon A/C works great for about an hour, then the airflow slows to a trickle. There might have been a hint of an electrical smell when this happened. If I switch to vent for a couple of minutes, the flow usually comes back for another 30 minutes or so. I have replaced the blower motor and the resistor pack. Ideas?
#164
Yes, I have shuddered at the thought of coils icing up. I had a home A/C do that once, and had to use the hair dryer to de-ice them. I figure if the car is doing that, I am looking at $1000 to replace the coils. My only hope was that it seemed unlikely that just a minute or two of vent would clear the ice. Also, the system gets nice and cold until it stops blowing), and I haven't had to add freon in years. Would an ice-up be possible without a leak? And if so, what can be done about it? Thx.
#165
That I do not know. I just offered the most likely cause I could think of.
It might be worth having a professional look at it and eliminating that possibility if you can. Some have a free diagnosis offer.
Good Luck.
#166
Did some researching on the coils freezing idea and that really sounds like the most likely problem. I was glad to read that there were possible causes for the problem that might NOT result in having to take the entire car apart to replace the coils. I'm taking it in Tuesday. Appreciate the advice.
#167
#169
Climate control
I am having a problem with my 2003 NEON SXT heat.
I have gone through the steps to what most common problems are from changing thermostat, and heater core with NO LUCK. so I started playing with ***** and realized my Vents dont change either. Its locked with ALL vents open and blowing.
I took apart most of my dash and found what must be the issue. There are Broken "gears" so to speak in the back. The wire that controled the gear in question does not connect to anything (so guessing heat stuck on cool) and the gears that change the vent theres a "lever" thats moves up and down thats broken.
I decided to stop by my local Dodge Dealership and Service location, to be told they will charge $100/Hour! I refuse to pay that, I have done most of the diagnostic and labor taking it apart, but feel they will take thier time to replace it and charge me outrageous prices for something that should be almost pretty simple
I have tried googling a bunch of things from "Neon Climate Control wiring", "Inner Dash Heat Gears" I cant seem to find anything pointing me in the direction I need.
I live in Upstate NY and winter is approaching quickly, I travel 30-40 mins to work, I cant even defrost my window to see.... Someone please HELP
#170
I have a 2000 dodge neon with a new radiator , thermostat and heater core has been flushed.I can not get any heat in the car. I have blocked the radiator 100 percent and still no heat ! Any thoughts or ideas what might be causing this? Winter is here and burrrrrrr its cold .Thanks for any and all help !
