Neon 2003 - Auto Transmission leak
Hi,
I have a Dodge Neon 2003 automatic transmission leak coming from the front close to the radiator, can you help identify what part of the transmission it is and to fix it?
Is is very involve repair?
Can I do it myself?
Can I use silicon/RTV?
What need to be remove to fix?
Do I need to drain the transmission completely?
What kind of tool, I need to tighten the screws at the junction where the leak is?
etc...
Best regards,
Sylvain
Can I do it myself?
etc...
Best regards,
Sylvain
I'm gonna guess it's the transmission cooler or lines to it. It looks like a separate unit. some cars have it attached to the bottom of the radiator so you have to replace the whole thing. It could be as easy as removing the cooler and hoses. Everything under the hood is so tight in these cars you may also have to pull the radiator. Good luck
https://search.yahoo.com/search;_ylt...p&fr=yfp-t-671
