ECU Replacement Problems and Questions.
Hi, Was driving down the highway in my 2003 neon and stalled out. Had to replace sensor that effects the cruze before that. Towed home and did a test to find no spark. Replaced the Throttle position, Cam position, and Coil Pack, and still no fix so now I'm down to the ECU because I don't see any issue with the wires.
The car has the special security key that prevents the car from starting without it. Is this going to be an issue where if I replace the ECU it still wont start because of the key thing? Is it possible that this feature is causing the no spark in the first place? Was also worried about the mileage and if it will change it when the ECU is replaced. Any other things to worry about? How do I go about finding the correct part/part number?
Thanks in advance.
Thanks in advance.
