over heating issues
Old 06-21-2014, 12:25 AM
pigpen6232003's Avatar
pigpen6232003
pigpen6232003 is offline
Default over heating issues
OK I need to pick brains for a min. 2001 Dodge Neon. Had water pump replaced last week as well as spark plugs. Car started over heating some times ran normal most time. Mysteriously losing water but do not see a leak. Replaced thermostat today. Car ran fine all day. overheated once tonight, then went back to normal. No white smoke. No oil in water, no green film on spark plugs.... Anyone have any clues I am at a loss
Old 06-21-2014, 10:36 PM
pigpen6232003
Default update
did find a crack in the radiator today replaced with brand new radiator. overheated again tonight....so new fuel pump, new thermostat, new radiator... any ideas anyone
Old 06-23-2014, 05:45 PM
sbhawaiian's Avatar
sbhawaiian
sbhawaiian is offline
It looks like you covered all the bases. I did help a fellow forum neon owner a while back. He could not find his over heating problem. What happened was when he had the engine flushed he said more than a gallon of rust came out of the engine.
Since the thermostat comes out easy you might want to try taking it out and see if it overheats(you will need thermostat gasket). Make sure you put it back after. Good luck
Old 07-10-2014, 08:23 PM
apollobmorelos's Avatar
apollobmorelos
apollobmorelos is offline
hello there. I am new to the forum and I don't know how to post yet. My question is about my radiator fan on my 2002 dodge Neon. is it normal that I can feel the air blowing towards the grill when I put my hand in fron of it? I am thinking I a might have some sort of polarity issue here. What do you think?
Quick Reply: over heating issues
