only getting 10psi of boost out of stock tunro
Old 03-03-2015, 01:46 PM
Steve20's Avatar
Steve20
Steve20 is offline
Default only getting 10psi of boost out of stock tunro
I have a 98.5 24v ISB with a holset hx35w turbo and I use to get around 15 psi I took the silencer ring out and was pushing 15 then it came down to 10 and cant get any more than that there's alittle shaft play but not very much. I think the waste gate could be stuck open but im not really sure just looking for some help
Old 03-04-2015, 01:48 AM
horatio102's Avatar
horatio102
horatio102 is offline
How's your fuel pressure? You need fuel to make boost, no fuel = no boost.
And you should have been running quite a bit more than 15 psi. It's entirely possible that your wastegate is stuck open, but knowing you've got a 24 valve I'd verify your fuel pressure ASAP before you smoke your injection pump, if it's not too late.
I regularly hit 35psi, where my wastegate is set. When my diaphragm ruptured and the wastegate didn't open, I hit about 55.
Old 03-04-2015, 10:31 AM
Steve20's Avatar
Steve20
Steve20 is offline
I have a new vp44 and the airdog2 100gph and I have it set to 15psi
Old 03-04-2015, 11:03 PM
horatio102's Avatar
horatio102
But what does a gauge say?
A bad overflow valve would cause lower pressure. Or a bad airdog.
Old 03-13-2015, 01:28 PM
BB_cuda's Avatar
BB_cuda
BB_cuda is offline
Wouldn't you be concerned about overboost shortening the life of your turbo? Too high of boost means turbo is spinning too fast. I say this not being familiar with capability of turbos on cummins. I'd like to keep my turbo at or below 30 psi.
Old 03-13-2015, 04:33 PM
horatio102's Avatar
horatio102
Supposedly 35 is about the top of the turb's efficiency range. 30 is safer, no doubt
Quick Reply: only getting 10psi of boost out of stock tunro
