No turbo boost
Old 10-18-2012, 03:59 PM
CONSTRUK's Avatar
CONSTRUK
CONSTRUK is offline
Thanks Jigabop, that was going to be my next question..lol
Old 10-19-2012, 07:27 PM
dragracin78's Avatar
dragracin78
dragracin78 is offline
My truck run fine too. no cel but was real doggy. no boost. it was like 90 bucks at autozone. code reader wont work unless it has a data display mode. you need to see what the sensor is actually telling the computer the boost is. I had an old pressure gauge I put it on the turbo where the wastegate hose is and had 3 psi when i tried to brake torque it. done same thing with scanner hooked up and it said 0 psi boost.
Old 10-20-2012, 02:06 PM
CONSTRUK's Avatar
CONSTRUK
CONSTRUK is offline
Thanks dragracin78...I was checking them out online and found one for 89, haven`t checked with CarQuest yet (they are the only auto parts store here except for Napa).
As for a reader, I found one online for $89.75 which hooks up to your laptop and does a host of things. Software is included and 24-7 support if needed. Here`s the link in case you want to check it out.
http://www.obdcom.com/
I am definitely going to get one for future use.
Quick Reply: No turbo boost
