2011 Ram 110 power inverter issue
Old 09-06-2015, 02:14 AM
SquidsInk's Avatar
SquidsInk
SquidsInk is offline
Default 2011 Ram 110 power inverter issue
I have a 2011 Ram 2500 4X4 and my 110 volt outlet stopped working. I push the button, the light comes on and approx. 30 seconds later it,goes off. It doesn't matter if anything is plugged in or not, the result is still the same. Anyone have this issue??? Or a fix???
Old 09-07-2015, 09:23 AM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
I know it's programmed to shut off after 30 seconds off no draw so that easily explains why it shuts off with nothing plugged in. Is what you are plugging in actually pulling a draw? If so, I'd say that sensor that tells the PCM it's in use is fubar. No clue how to fix that. Could be physical could be software. Any TSBs out for it???
Quick Reply: 2011 Ram 110 power inverter issue
