2008 6.7 dpf full with delete
Old 09-14-2016, 07:40 PM
jman21's Avatar
jman21
jman21 is offline
Default 2008 6.7 dpf full with delete
I have a 2008 2500 6.7. I just did a full egr and dpf delete pipe. I'm running the edge attitude with juice. I have codes but read that's common with the edge. 2 days into this the over says I'm 90% full and now says full power reduced and nothing I can do will clear it so far. anyone have any suggestions. tia
Old 09-14-2016, 09:19 PM
p38251's Avatar
p38251
p38251 is offline
Check with edge on updates. I would not be satisfied with codes after spending money on a tuner. Not sure about edge stuff. I run H & S.
Old 09-14-2016, 09:20 PM
p38251's Avatar
p38251
p38251 is offline
Did you unplug all exhaust sensors? And the metal pressure tube?
Old 09-14-2016, 09:45 PM
jman21's Avatar
jman21
jman21 is offline
yea everything is unplugged. I undid the 2 Metal lines off the exhaust at where they connect to the rubber ends, they are not plugged. I did plug the throttle valve back in but the gear is removed. I cleaned the map sensor before this also.
Old 09-14-2016, 09:47 PM
jman21's Avatar
jman21
jman21 is offline
yea it's kind of a bummer. I had the programmer 1st, personally wouldn't have chosen it now. not sure if it can even update either. even if I clear the codes before startup they are still there.
Quick Reply: 2008 6.7 dpf full with delete
