Turnsignal/Hazzard Flasher Location
Driving my 1999 Dodge Ram 1500 Van the other day and everything worked fine. Went around a corner and the turn signals didn't work. Immediately put the hazzards on and they blinked 2 times and quit.
Is it bad flashers that are causing this? Where are the flashers located? I can't find them....looked under the hood, pulled cover off fuse panel and looked under dash.
All input appreciated~~~~~~~Thanks..........Ron
Still Not Working!!!
I had a similar problem (no brake lights or turn lights) a couple of years ago and someone suggested replacing the multi-function switch which I did and still had the same problem. Come to find out....there was corrosion in the box under the dash where all the wire come from outside. Cleaned it up and used dialectic grease and cured the problem. I took the box apart this time and their is no corrosion.
I checked fuse in fuse panel and fusible link under hood. All OK!!! I'm stumped. Anyone have any suggestions? Thanks~~~~Ron
