o2 sensor
Old 02-15-2010, 10:15 AM
jiggiwdit's Avatar
jiggiwdit
jiggiwdit is offline
Default o2 sensor
I have a 98 3500 5.9. O2 sensor code came up. Bank 1 sensor 1. Which one is that? There are 4 correct? What happens driving around with a bad o2 sensor?
Thanks.
Lee
Old 02-15-2010, 02:20 PM
alloro's Avatar
alloro
alloro is offline
Van & CUV Section Moderator
Dodge Forum Moderator
On any engine bank 1 is the side with the #1 cylinder. Sensor 1 is the one before the catalytic converter (upstream). So in your case, it's the driver's side before the cat.
Old 02-15-2010, 03:59 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Mobile Auto Repair is offline
Dodge vans (96-03) only use 2 sensors, one before the cat and one after. So the one at the cat inlet is the one that has the malfunction.
Old 02-15-2010, 08:30 PM
jiggiwdit's Avatar
jiggiwdit
Is this something I should change right away?
Old 02-15-2010, 09:58 PM
Mobile Auto Repair
Yes it should be changed very soon. The PCM uses this one to decide how much fuel to give the engine. With out it working the PCM will stay in Open Loop which will use more fuel and cause the catalytic converter to clog up sooner than you want.
Old 02-16-2010, 10:00 AM
jiggiwdit's Avatar
jiggiwdit
Thanks.
Lee
Quick Reply: o2 sensor
