1995 ram van drl module location
Drl problem?
the van is actually a roadtrek camper van conversion made in Canada . what happened is I was driving home to Canada from Florida hit some rough roads when stopped for dinner the headlight would not turn off even without the key in the ignition some one in the resturant said it was more than likely my drl module . is that the most likely problem ? any sugestions?
If it was intended for the canadian market, then DRL would've been required since 1990.
I'd think a Mopar DRL module would've been used, part 56004262, looks like a lil black box pager. Don't know where it'd be, perhaps above driver fender, mounted on the firewall, etc.
Otherwise, check relay/fuse.
Lastly, switch itself went bad.
Looking through my 94 FSM (perhaps 95 is the same) there is in fact DRLs on Canada models. The DRL relay is under the glovebox. The DRL module itself is in engine compartment side, specifically on the underside of the windshield cowl. Its next to the windshield wiper motor. It looks like the module I linked in the previous post.
