1978 Dodge Tradesman 200 360 2bbl
Old 08-25-2014, 01:33 PM
drm7171's Avatar
drm7171
drm7171 is offline
Default 1978 Dodge Tradesman 200 360 2bbl
Hi, thought I would ask on this forum.
I have the van indicated in title, and when I am accelerating the vehicle, it feels like it is hesitent to go, very sluggish. Now, this does not happen if Van is in park and pushing on gas pedal.
I have replaced plugs, wires, cap, rotor, fuel filter, air cleaner, pcv valve, cleaned carb.
Any idea's?
It starts up fine, and feels liek its running fine when I get to desired speed.
Old 08-26-2014, 04:05 PM
iodj44's Avatar
iodj44
iodj44 is offline
Could be the accelerator pump in your carb.
Old 09-01-2014, 11:23 PM
drm7171's Avatar
drm7171
drm7171 is offline
Default Accelerator pump
I was able to check the acc pump by looking down the carb with the engine off, and press on the gas pedal. It did spit a squirt of gas into the carb without a problem. I am starting to think timing may be an issue, but I am unable to locate the timing marks on this engine. Any ideas where the timing marks are? I would like to check it out, and at least be sure that is correct.
Old 09-02-2014, 06:45 AM
iodj44's Avatar
iodj44
iodj44 is offline
Clean the grease off your timing cover, the reference marks are molded in, that being said I do believe your issue is fuel related.
Electronic ignition is very reliable only weak spot and infrequent is the distributor and does not sound like what your going through.
Old 09-26-2014, 10:16 PM
drm7171's Avatar
drm7171
drm7171 is offline
Default Accelerator Pump
It turned out to be the accelerator pump in the carb, after had the carb rebuilt from a former drag racer, he also explained it also was the problem.
Thanks!
Old 10-09-2014, 11:04 AM
arthur1920's Avatar
arthur1920
arthur1920 is offline
Default slug acceleration
Lucky you.
I had the carb rebuilt twice and it still hits "the wall" when accelerating and shifting to second.
And it has done that since the day I brought it home new in 1979.
Quick Reply: 1978 Dodge Tradesman 200 360 2bbl
