Need CA smog help ASAP
Yes, the OEM plug may need to be spliced, but the connector will be OEM and not a "computer connector". Which O2 sensor is missing? 96 is OBD2, so there should be one before and after the CAT. I would have been telling that person to show me what he was talking about before ever leaving that station.
Both O2 sensor were hooked up and running fine
He just did not like that the wires were into a NON OE plug. Told me per the law, they had to be OE, and were not allowed to be spliced in. I told him I went to the dealership, to get the pins and plug, and they don't offer the pins separately, it has wires already connected to the pins, and has to be spliced into the main harness.....
Here is the part offered by the dealership:
[picture is from NAPA autoparts, but the dealership has the EXACT same thing]
yeah.... well I got some harness from pick n pull. jsut gotta tap it in now.....
then going to a friend of a friend, that said he knows what is wrong, and will fix it... said $60 to look at it, and then the fix will be $100
he sounds pretty certain it is the head or heads -- however, I have only chatted with him over text and through my friend.....
