I have a 2001 Dodge conversion. Van Ram 1500, can someone tell me how to check the blower switch , front works fine , rear doesn't, check front fuse box didn't see fuse for rear , is here one ... And where is it Thanks for any help
Start by checking for 12 volt power at the rear blower motor (key and heat on). If power is there then it's the motor that's no good. Your next step is to remove and inspect the blower speed resistor to see if it's burnt.
Ok thanks , going to look at it this weekend, but were would the blower speed resistor be at if that is the case, I'm new to all this... And this forum is fantastic
Finally got to It this past weekend,Took off the back Grill to a blower found a 15 amp fusejust had to replace it,should've looked at it first before asking for help ,thanks again
I have a 2001 dodge van and I had took the heater hose lose , to replace the cracked plastic fittings and the two vac fittings . And can't how they went after it sit for a month
