pcm module c3
I am thinking you are wanting the pin out of the third connector on the PCM?
My connector colors left to right are gray white black. Pinout number very small printed on plug end. I used masking tape to ID wires then plugged back in.
Local Dodge mechanic printed out his pinout ( I don't have printout) and gave me some voltages to check...
BLK connector pin 17 5V
pin 2 12 V with key on pin 22 12v always pins 31-32 ground
WHT pin 31 5V
hope this helps a bit
WHT pin 31 5V
PCM Connectors
RSDATA, I think you have given the answer to what I have been looking for. According to your descriptions, the physical arrangement of the PCM connectors is: Left-to-right is C3, C2, C1.
The pinouts you just gave match the wiring diagram for my '01 5.9L....problem with my harness and diagram is they're all black, no grey or white connectors. this'll help a lot, thanks.
