1991 dodge van
Old 07-19-2016, 10:04 AM
Stan Coffey's Avatar
Stan Coffey
Stan Coffey is offline
Default 1991 dodge van
Hi guys & gals
Here is the problem van with 318 engine turns over but not run
it has no spark, no voltage at coil & no fuel from injectors
as you keep trying to start it cycling the ignition switch every once in a while it will start and runs perfect any where from 30seconds to 5 minutes
then dies & again has no spark no voltage at coil or fuel from injectors
Ive checked voltage at ignition switch & it is fine
I'm leaning to it being the engine controller ?
Thanks
Old 07-19-2016, 01:15 PM
jkeaton is online now
Dodge Forum Administrator
Moved to the correct section.
Old 07-27-2016, 10:17 PM
Poagman's Avatar
Poagman
Poagman is offline
Bad ground could do it.
- Battery to block
- Under the ignition coil
Also, check the PCM power cable from battery. There is a pull-apart connector that could be loose of corroded.
Old 07-29-2016, 04:28 AM
Friar Tuck's Avatar
Friar Tuck
Friar Tuck is offline
Lightbulb
You will only get power to the coil and injectors for ~3 seconds if the sensors fail to tell the PCM that the engine's turning over.
See if you get spark when the starter starts turning.
Also, be sure there is good fuel pressure and that it holds for several minutes.
Old 07-30-2016, 09:57 AM
Moparite's Avatar
Moparite
Moparite is offline
Check that the asd relay is coming on(and supplying power). As said above it will not stay on so you need to check it as soon as you turn the key or when cranking.
Quick Reply: 1991 dodge van
