Project Brainstorm - Couple Questions !
Greetings,
I am putting together some ideas for a project and I have a few baseline questions. I'm targeting a '77 Tradesman so most of my questions should lead to as close to a '77 as possible.
Were there any standard length Tradesman vans that were factory 4x4?
Regarding the frame under a '77 Tradesman, what was the span of years that frame was used?
Has anyone seen or heard of a modern Hemi in these old vans? I believe some were big block equipped, so that indicates a decent amount of room to play with.
Thanks.
Thanks.
I'd definitely go with a stand alone system, if I could incorporate all related systems from a donor truck into the van. Heck I was kinda even thinking of putting the truck dash assembly and everything in the van anyway.
My main concern is, is there enough room in the van for the Hemi? I would assume it's bigger than the big blocks, but I just don't know for sure.
